Mystery cooling and heating problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 08-02-2016, 09:57 AM Thread Starter
Crowley
crowley1027's Avatar
Anyone got any ideas? Never bothered to replace the thermostat during the rebuild, since there wasn't much of an issue. Guess I should have.
crowley1027 is offline
post #2 of 17 (permalink) Old 08-02-2016, 10:43 AM
What the actual farley?
How the heck does a roofing nail get in there? Dropped in a drain pan by accident? But then how does it get through the radiator cores to the t-stat?
Somebody tried to block the 'stat open?
I give up.
That's a long roofing nail ... Anybody close by tear off three layers of old roof recently?
post #3 of 17 (permalink) Old 08-02-2016, 10:48 AM Thread Starter
Crowley
I give up.
Yeah, I'm dumbfounded. Looks like it was dropped through the cap area, and lodged in the stat.
post #4 of 17 (permalink) Old 08-02-2016, 11:03 AM
im gonna guess someone in the past stuck that nail in there to block the 'stat open. I cant think of any way for it to have gotten in there without disassembly of the housing..
michiganteddybear is offline
post #5 of 17 (permalink) Old 08-02-2016, 11:06 AM
Pretty wild. Sabotage or dumped from a drain pan, that's all I got.
Damn! That's about the weirdest thing I've heard of being found in an engine. 2nd place might be a carb screw embedded in a piston, engine still ran fine, but had a noticeable thump-thump-thump.
post #6 of 17 (permalink) Old 08-02-2016, 12:37 PM
Expendable newbie
evulcannibal's Avatar
Hopefully, that's the only foreign object in there.
Might want to check to see if you can find anything else in there just in case.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #7 of 17 (permalink) Old 08-02-2016, 01:30 PM
Gremlins.you need a gremlin bell
post #8 of 17 (permalink) Old 08-03-2016, 08:17 PM Thread Starter
Crowley
OK, now a real mystery (or maybe not).
I replaced the stat and rad cap, all hoses tight, overflow going to the bottle, vent going out.
Rode to work, warmed it up nice, parked it.
Went out 2.5hrs later, opened the rad cap, and got a pressurized POP sound. Nothing gigantic, but definitely pressure of some sort.
Rad cap is same pressure rating as the old one 0.9bar,so I don't know why it would pop like that.
Could the cooling system have been at 0.7 bar, not enough to lift the seal in the cap?
post #9 of 17 (permalink) Old 08-03-2016, 08:22 PM
yea, it could have had some pressure in it still, but not enough to open the vent
post #10 of 17 (permalink) Old 08-03-2016, 09:32 PM
Agree with mtb, or could have been the last of the air burping out.
