Buying an MCCT kit from eBay - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 2 Post By Chris and Shim
post #1 of 7 (permalink) Old 05-27-2016, 04:18 AM Thread Starter
Question Buying an MCCT kit from eBay
Was super smart (sarcasm, obviously ) and bought a Vulcan with almost 44000 miles on it. I like the bike quite a lot, except the god awful stock seat which destroys my butt in about an hour of riding. I also think the performance is lacking when riding with a passenger, but I guess you can't expect the world from a 750. Fairly quick when I ride alone though
The engine though, has a decent amount of rattling, and I'm planning a long trip this summer with the bike. Having a passenger the entire trip will strain the bike all the more, so I really want to be able to rely on it. I've looked at the DIY MCCT guide where you assemble the parts yourself, but I am anything but handy with tools. I work in IT and the extent of my mechanical skills basically stop at assembling desktop computers from scratch, and some light laptop repairs. My brother is a master mechanic though, thank god, so I'm sure I can persuade him to help me do the conversion.
The site apparently has an anti-spam rule where you have to have minimum 5 posts under your belt before links are allowed, so I had to break it up.
(http)://www.ebay.com/itm/MANUAL-CAM-CHAIN-TENSIONER-RED-1986-2006-KAWASAKI-VULCAN-750-VN750-VN-T10-/141170999745?fits=Year%3A1993%7CMake%3AKawasaki%7C Model%3AVulcan+750&hash=item20de7281c1%3Ag%3A8eYAA OxycmBS3biK&vxp=mtr
I've been looking at MCCT kits on ebay. Something like the one above, for instance. I know it's vastly(!) overpriced, but the assurance that you're actually getting the right parts is worth quite a bit, to me.
Two questions:
1. Can you install this without removing the engine etc? If yes, how long does it take approx?
2. Does anyone have any experience with one of these kits?
Edit: in the picture; that's the ACCT right? I read somewhere here that a bracket to the oil line can be bent so you do not have to remove the engine. Looks like someone beat me to it? lol
Python is offline
post #2 of 7 (permalink) Old 05-27-2016, 05:08 AM
Tinkerer
Gaz73's Avatar
Hi Python,
I bought my MCCT kit from eBay see link below:
CNC Blue Billet Manual Cam Chain Tensioner For Kawasaki VN 750 Vulcan 86-06 | eBay
Build quality is good on the ones I bought.
Yes you can fit these with out removing the engine, doesn't take very long to do.
There's plenty of info in the Vulcan Verses to keep you right.
Man can not live by bread alone... he needs Duct tape & WD40
Gaz73 is offline
post #3 of 7 (permalink) Old 05-27-2016, 07:50 AM Thread Starter
Originally Posted by Gaz73 View Post
Hi Python,
Fantastic. Maybe I should try the "Grambo Trick" first though, just to be sure. Thanks for the reply.
Python is offline
post #4 of 7 (permalink) Old 05-27-2016, 08:08 AM
Mod
Birdhunter02's Avatar
You might want to find a shorter bolt for the right side as the reservoir is in the way. Can't remember the company that makes it but it's much shorter then most. You really can make it yourself very easily. Good luck.
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is offline
post #5 of 7 (permalink) Old 05-27-2016, 08:27 AM
Yes, stock seat sucks. I ended up getting a Corbin, and my wife found it more comfortable too..... However I didn't notice much power loss with a passenger... Guess it matters what you both weigh...
post #6 of 7 (permalink) Old 05-27-2016, 02:17 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
I bought my MCCTs from TOC. It actually took me longer to find where my correct sized wrenches were than to swap out the front one. I had a thread going in the not too distant past where I asked basically how to adjust them. It's simple. Just finger tighten the main bolt until the clacking sound from the chain stops and then give it a 1/8th to 1/4th additional turn and tighten it in place with the nut. The back cylinder takes just a few minutes longer due to the over-flow tank needing to be unscrewed and moved out of the way. But the whole thing can be done from sitting in the living room, to the bike, to sitting in the living room in a half hour or so. (Assuming you know where the wrenches are.) On the subject of seats, your assessment is correct. Speaking for myself, the stock seat wasn't comfortable so I had one made.
WilliamTech and Python like this.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #7 of 7 (permalink) Old 05-27-2016, 05:13 PM Thread Starter
I just bought the one I linked in the first post. I didn't realize until now that there are two tensioners though. My father didn't see it either. Tried the Grambo Trick tonight. Removed the whole tensioner (left side), tested the spring a few times and put it back on. Fired it up and it was quiet for a short time before the rattling came back. At least I know the problem now
Is it cool if I run one MCCT and one ACCT? Waste of money replacing a functional part, imo.. At any rate, it must be an improvement, since the left one is broken anyway.
I haven't found anything on eBay except used stock seats.. I'm considering just getting a touring "pillow", or whatever they're called. I don't ride for more than an hour straight often anyway. I weigh around 145-150 lbs , she's around 100-105 if I were to guess (she's tiny). Maybe I'm oversensitive to these kinds of things, hehe.
Very good tip there on how to adjust it! It'll help for sure. I guess the back cylinder one is fine since the noise was pretty much gone after I tested it (for a minute). Guess I can pick a second one up later. They're pretty damn expensive.
I'd love a custom seat myself, but I'm probably not going to have this bike for more than a year or two at the most. I'm starting to drool over a Sportster XL Custom 1200 (hoping that statement doesn't get me banned from the site!).
Python is offline
Tags
mcct
