MCCT adjustment video - does this sound right? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 05-21-2016, 10:34 AM Thread Starter
Can anyone tell me if this sounds right:
With the exhaust leaks and new intake draw from less restriction I just can't tell what is engine noise versus other sounds. I know netmatrix01 shared his overtightening MCCT destruction story and I want to avoid that!
Does this sound okay to run the bike (@ home only) until I re-jet and get exhaust gaskets replaced?
Once I get it tuned in right. I will do the JB Welded 6mm nut on inside housing.
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #2 of 10 (permalink) Old 05-21-2016, 02:12 PM
I think I heard the clacking start at 50seconds. You were then overtightening it seemed like.
When installing the MCCT, it should JUST be touching the chain guide. You can feel it when manually turning the tensioner when it makes contact with the guide
Start the bike. It should still clack from that cyl. Use a screwdriver as a stethoscope (this is the big thing), Even with a bunch of other sounds it is 100% identifiable.
Slowly turn until clicking goes away, no more than a 1/4 turn after noise dissipates. Blip throttle makes sure it doesn't clack then.
post #3 of 10 (permalink) Old 05-21-2016, 10:51 PM Thread Starter
thanks will try and report back. Never tried the screwdriver trick before - learning lots here
2002 vn750
40/138 jetting
gidaeon is offline
post #4 of 10 (permalink) Old 05-23-2016, 12:23 AM Thread Starter
A little more progress. For the first time since I tore engine out I got to drive around the yard for a while.. better than nothing.
I can now discern the clacking sounds very clearly versus the other taps, ticks etc., I ordered exhaust gaskets but am wondering how calebj got his so smooth and quiet after his MCCT conversion (awesome vids for comparison in "my acct conversion thread" thanks for posting those man!
2002 vn750
40/138 jetting
gidaeon is offline
post #5 of 10 (permalink) Old 05-23-2016, 12:33 AM
It does sound a bit clacky. Where is the sound coming from? use the screwdriver to pin point a location
post #6 of 10 (permalink) Old 05-23-2016, 09:06 AM Thread Starter
Its general noise from the top end, i think near the cams/rockers/HLA. Screwdriver does not transmit anying obvious to me :-( mote like constant "grinding" bad word i know. Maybe its the lifters?
I did not bleed my HLAs as it was not recommended to by an extremely knowledgeable member i trust. I could not push any of them in at all prior to rocker install.
The little flat springs on rocker arms i torqued right but am not 100% the angles are perfect (orientation is definitely correct though). Bike seems to run fine and have power.
2002 vn750
40/138 jetting
gidaeon is offline
post #7 of 10 (permalink) Old 05-23-2016, 12:50 PM
The VN engine isn't very quiet, there's a lot of mechanical noise. Could just be the lifters as you note. The angle just made it kinda loud but mine will sound like that at a specific angle too
post #8 of 10 (permalink) Old 06-03-2016, 01:26 PM Thread Starter
I noticed my rear cyl. Mcct is adjusted quite a bit further out than the front (3+ threads more) Is this normal?
gidaeon is offline
post #9 of 10 (permalink) Old 06-03-2016, 01:33 PM
My front and rear adjusted the same.
post #10 of 10 (permalink) Old 06-03-2016, 01:38 PM Thread Starter
Hmm.. Uh oh. I guess i need to recheck or my neoprene bonded washer are tighter by a few threads on one or the other.
2002 vn750
40/138 jetting
gidaeon is offline
