Coolant Reservoir Tank Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 05-20-2016, 09:35 AM Thread Starter
Tinkerer
Gaz73's Avatar
Does anyone know how much coolant the reservoir tank holds? Or what the difference in fluid level/amount between the Minimum & Maximum marks are?
Reason I'm asking as I want to install a custom made tank.
Cheers in advance, Gaz
Man can not live by bread alone... he needs Duct tape & WD40
Gaz73 is offline
post #2 of 14 (permalink) Old 05-20-2016, 06:26 PM
2000 VN 750 Senior Member
You can easily disconnect it and refill it with water which then can be poured into a large measuring cup if someone does not come up with the answer quick enough for you.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #3 of 14 (permalink) Old 05-20-2016, 06:33 PM
it probably isnt real important how much it holds, as long as it holds 'enough'
post #4 of 14 (permalink) Old 05-20-2016, 07:05 PM
Expendable newbie
evulcannibal's Avatar
I have a crappy memory, but here goes. The L mark is roughly half the size of the F mark (I think this is also true of most radiator reservoir, at least it was on my car). I used a water bottle and filled it up about 1/4 of the way twice, once with water, second with radiator. First time went above L mark and second time went above F mark. So a guess would be 6 to 8 oz total to full mark.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #5 of 14 (permalink) Old 05-20-2016, 09:44 PM
Total coolant capacity is 1.6 IMP QTS. (1.9 US quarts)(1.8 Litres), or just under 8 cups.
I just went out and looked at my scoot. Just eyeballing the coolant tank cover, I estimate the total tank capacity holds perhaps 3 cups. Two cups up to the Full mark.
Vulcan2000 gives you the easiest way to determine what you want to know.
post #6 of 14 (permalink) Old 05-21-2016, 04:11 AM Thread Starter
Tinkerer
Gaz73's Avatar
Cheers for the reply's guys, just wasn't sure how critical the amount of coolant was needed in the reservoir is... measuring jug will be out later
Gaz73 is offline
post #7 of 14 (permalink) Old 05-23-2016, 11:26 AM
I am sure you already thought of this... But because im the guy that usually doesnt: Did you do/will you do mcct conversion? if so make sure things "fit" with replaced custom tank.
gidaeon is offline
post #8 of 14 (permalink) Old 05-23-2016, 03:40 PM Thread Starter
Tinkerer
Gaz73's Avatar
Good thinking... I am pulling the engine out this week, but I'll do a mock up with the new tank in place just to make sure everything fits
Gaz73 is offline
post #9 of 14 (permalink) Old 05-23-2016, 03:53 PM
Yup had to space the stock one on mine
post #10 of 14 (permalink) Old 05-26-2016, 03:20 AM Thread Starter
Tinkerer
Gaz73's Avatar
Looks like I'll be sticking with the stock one, my custom made doesn't sit right... ah well I'll stick it on the self for a future project
Gaz73 is offline
