Do the numbers on dampers mean anything? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 1 Post By OleDirtyDoc
  • 1 Post By michiganteddybear
post #1 of 7 (permalink) Old 05-13-2016, 01:30 PM Thread Starter
Put new dampers in today. I notcied 2 things 1) lots of rubber flashing; is that a QC issue or purposefull?
2) what do the different numbers mean? Weight? (Probably not or order would matter right) i was surprised all were different numbers so i doubt yhey are date codes
gidaeon is offline
post #2 of 7 (permalink) Old 05-13-2016, 01:37 PM
iirc..... 5 dampers....3 small(er) - 2 Large(r)..............
Damper will fit BOTH correctly AND 180 degree's out. BE CAREFUL !
Also, LEFT_ HAND THREAD Bolt.... 13 ? ft. lbs. ?
Use Lock-Tite...
Any/all comments welcome here..............
WilliamTech
ps: I would guess flashing is extra rubber for your money .... - -
post #3 of 7 (permalink) Old 05-13-2016, 01:41 PM Thread Starter
[quote=WilliamTech;1086994]iirc..... 5 dampers....3 small(er) - 2 Large(r)..............
Use Lock-Tite...
WilliamTech[/quote
I just pu the bad flashing side in deep and figured it will wear?
Theres 6 total dampers. The star shapes ones go on the "outside" see through holes in gear. That LH bolt should be 51 ft lbs. Just like the right side.
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #4 of 7 (permalink) Old 05-13-2016, 01:44 PM
Use Lock-Tite...
WilliamTech
I never get extra rubbers for flashing.I just politely get told to put my clothes back on
Thorn likes this.
post #5 of 7 (permalink) Old 05-13-2016, 02:55 PM
flashing is probably just excess material injected into mold, and not cleaned off..
numbers are probably the mold cavity that particular item came out of. I am sure they make several, if not dozens of them every time the mold halves close.
gidaeon likes this.
post #6 of 7 (permalink) Old 05-14-2016, 01:02 PM
I have never seen a vn750 engine apart, so I have a question. Some sources I have read say there are 6 rubber balancer dampers, and others say there are 4 rubber and 2 plastic dampers. Which is right? What came in your kit?
One more question; is that a steel bushing/sleeve in the center of the rubber damper in the pictures?
post #7 of 7 (permalink) Old 05-14-2016, 03:12 PM Thread Starter
There are 6 total, 4 of one part # and two of another. The two star shaped ones (not show in my pics) are a slighty softer material IMO than the four donuts ones pictures again, IMO.
The two that are noy round do not have sleeves. The other ones probably have aluminum sleeves? I kept the old i could look later.
I have the origonal bags and can get pictures of the kawasaki labels if it helps anyone.
2002 vn750
40/138 jetting
gidaeon is offline
