lash adjusters - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 04-23-2016, 05:16 AM Thread Starter
JETHRO's Avatar
lash adjusters
hi all, winters over so ran the bike to warm up and seems ok but for ticking noise on front cylinder head so i'm thinking lash adjusters replace but on schematics it shows two different types one set has o-rings, are these upgrade versions and should i install these instead of original type with no o-rings the bike runs quiet when cold so is there any other reason for this maybe different oil etc. thanks Jethro
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
post #2 of 5 (permalink) Old 04-23-2016, 11:06 AM
Could be the cam chain tensioner?
post #3 of 5 (permalink) Old 04-24-2016, 05:17 AM Thread Starter
JETHRO's Avatar
cam tensioners
so is this ticking noise a common cct problem ,when i put my ear to the cylinder head the noise seems to be from the opposite side of the cam chains and tensioners ,not really bad but rear cylinder is quiet and be nice to have same in front. thanks
JETHRO is offline
post #4 of 5 (permalink) Old 04-24-2016, 12:01 PM
Look into mcct's
post #5 of 5 (permalink) Old 05-31-2016, 03:29 PM Thread Starter
JETHRO's Avatar
well ,having changed the lifters i looked closely at the followers and one of them was worn inside the cup, not easily to notice but when examining it i realised it was quite bad on one side ,so changed that as well and seems a lot quieter now, so hopefully cured .
JETHRO is offline
