Mechanical seal, weep holes leaking coolant - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-09-2016, 08:46 PM Thread Starter
Chiefchokesnpass's Avatar
Hey, I have a 2001 kawasaki vulcan 750 and she's leaking coolant out of the weep holes. From what I have read it's the mechanical seal. I'm having trouble finding the part number for the impeller o ring and lock nut. Can I just get a generic o ring and lock nut? If so what sizes?
Chiefchokesnpass is offline
post #2 of 6 (permalink) Old 04-09-2016, 09:55 PM
RoadHopper's Avatar
i would, if it's cheap and available and works. Worst thing that can happen is you'll end up where you started. I used common plumbing o-rings on my last oil-change, but that's oil. Was in the same situation though. . . had to have SOMEthing at least for "now".
( insert common every day disclaimer here. To be clear: i am NOT an expert. )
RoadHopper is offline
post #3 of 6 (permalink) Old 04-09-2016, 10:38 PM
2000 VN 750 Senior Member
Have you gone to the websites for Bike Bandit or one of the many other OEM parts dealers. Those sites are pretty good for getting the proper part number. Try a few of them. Also seeing this is your one and only post how about doing an introduction under the Newbie Check-In heading and tell us a bit about your riding/wrenching experience and where you are from.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #4 of 6 (permalink) Old 04-10-2016, 05:20 PM Thread Starter
Hey I was able to find the part numbers. And I will post updates. When I get home I'll type of a post in the newb forum. Thanks.
post #5 of 6 (permalink) Old 04-10-2016, 06:05 PM
calebj's Avatar
You have to do a fair amount of work to replace that seal. Definitely not worth being cheap given the minimal savings.
calebj is offline
post #6 of 6 (permalink) Old 04-10-2016, 06:36 PM Thread Starter
Nothing too complex though. Lookin at 60 in parts, than new oil/filter and coolant. Around 60 more.
Sent from my SM-G900T using Tapatalk
