Murphy's Law - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #21 of 35 (permalink) Old 04-09-2016, 10:26 AM
Hate to say but, looks like chunks of rod bearing material. That gold color, if I'm seeing it right..
Curious about those long strands though.
post #22 of 35 (permalink) Old 04-09-2016, 12:31 PM Thread Starter
calebj's Avatar
I was really hoping you wouldn't say that, but it's my guess as well. Can't think of anything else but a bearing. Sounds like I'm headed all the way to the crank. Yes, they're definitely gold colored. Seems to have come apart in fairly large pieces too.
calebj is offline
post #23 of 35 (permalink) Old 04-09-2016, 01:06 PM
Clutch material can be gold, but usually has some dark mixed in, and is usually a lot smaller chunks.
Looks like a hammered bearing. That stinks.
post #24 of 35 (permalink) Old 04-09-2016, 04:05 PM
I'm with these guys looks like bearing material
post #25 of 35 (permalink) Old 04-11-2016, 12:39 AM Thread Starter
calebj's Avatar
Making some progress. Still a fair number of things to remove, but at least the heads, chains, cylinders, and clutch are out of the way. There's definitely some obscene lateral play in the front connecting rod. Guess I'll be sourcing a used crank and rods.
ID:	29914   Click image for larger version
calebj is offline
post #26 of 35 (permalink) Old 04-19-2016, 09:49 AM Thread Starter
calebj's Avatar
And it's official. Heard back from the machine shop today that the crank is not repairable.
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #27 of 35 (permalink) Old 04-19-2016, 10:13 AM
mikesutch's Avatar
There's got to be a crank available on here. Sucks man. Best bike mojo coming your way..
Mosfet R/R and relocated
2 wire Mod for the 1986 harness
VN750.com grill cover
mikesutch is offline
post #28 of 35 (permalink) Old 04-19-2016, 11:17 AM Thread Starter
calebj's Avatar
There's one on eBay for $200. I may go ahead and order that today. At this point I'd prefer to toss in a used/running engine, but nothing's turning up locally.
1999 EN500 32k
calebj is offline
post #29 of 35 (permalink) Old 04-19-2016, 11:40 AM
Caleb, you might watch that auction and keep looking around, should be able to find one for less. I'm just a bargain hunter, time is more valuable than money for some, I know.
A couple of you guys are really getting your feet wet on the VN. I've built car engines, bikes, even nuclear subs over in Newport News. But when I built a 75hp outboard, I thought, "dang this is like a Swiss watch!" Then I saw the inside of this 750.
Good thing is, you have Roach's videos already.
Will keep an eye out for any parts.
post #30 of 35 (permalink) Old 04-19-2016, 11:47 AM Thread Starter
calebj's Avatar
I've been keeping an eye on Craigslist and eBay, and so far not much has turned up even when I look within a few hours driving distance. There's this listing:
1989 kawasaki vulcan for parts
I tried communicating with him and he realized it was an '86, then said it was a 1000cc engine rather than a 750. When I asked him if the motor ran, his response was 'Yea put it will need work to put into it for it to go'. I'm not quite sure what he meant by that, but clearly he's not on top of his game.
My engine experience is pretty limited. My grandfather led me through rebuilding a lawnmower engine when I was a teenager, and maybe 15 years ago I rebuilt a 2.8 in my old Bronco II with somebody else leading the way. Both of those had nothing on this. Like you said, though, the videos Roach put together are excellent. The shop manual is also pretty clear. My only frustration with it ties to the grainy pictures and the way it sometimes jumps around. Occasionally I'd pull a part off and later realize I needed it in place to lock things together to loosen another bolt. In one case, I somehow missed a step of removing the transmission cover. Easy enough to remedy, but I have no idea when that step was intended to take place and how I missed it. Still, all in all it's been pretty straight forward. Now I have a giant Rubbermaid tote full of carefully labelled bags of parts. Hopefully the reassembly process won't be too terrible.
1999 EN500 32k
calebj is offline
