Anybody using oil additive? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Spockster
post #1 of 4 (permalink) Old 03-18-2016, 10:18 PM Thread Starter
is anybody using oil additive such as Tuffoil or slick50 in their engine? I have been using Tuffoil on my pickup since I bought it in 96 and I am a convert. I am a little concern using on an engine with wet clutch.
Thanks,
Charles
guggech is offline
post #2 of 4 (permalink) Old 03-18-2016, 10:44 PM
I wouldn't, could end up with a slipping clutch, just using the wrong oil can do that.
Think I once used an early version of Tuffoil. Remember seeing that on the can, but it also had teflon in it. Combined with the dreaded graphite oil that was also new at the time, the Olds engine promptly went downhill. Don't think graphite motor oils exist any longer.
For the bike, I do use Seafoam in the oil once in a while, 200-300 miles before an oil change just to clean things up. Parts like valve stems, rings, starter clutch, etc. can cause a lot of problems if varnish builds up.
Seafoam in the gas keeps the carbs, combustion chambers, and piston tops clean, usually twice each year and for winter storage.
guggech likes this.
post #3 of 4 (permalink) Old 03-19-2016, 12:53 PM
I have seen no evidence on this forum from the years of collective experience here that oil additives are necessary for long-term health of a VN750 engine. Just change the oil every 3k miles, 5k with full synth, and you're fine.
post #4 of 4 (permalink) Old 03-19-2016, 01:55 PM
Oil additives reduce friction in high mileage motors. Wet clutches need friction. Reduce the friction and clutch no worky no mo.
