Replacing valve seals - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 03-16-2016, 06:08 AM Thread Starter
1985 VN-700
L2fish's Avatar
I am getting some smoking when I first start up and thinking its valve seals. Has anybody replaced theirs? I am thinking maybe I can used compressed air through the spark plug holes to keep the valves closed like I have done in a car. But, looking at the covers over the cam shafts and timing chains I am not so sure I can remove the cover without causing movement of the cams. Theoretically the tension on the timing chains should keep everything in place but its not bad to double check.
L2fish is offline
