Water out of exhaust..one cylinder - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 07-16-2005, 04:57 PM Thread Starter
Bike running on one cylinder and water slowly dripping out of rear cylinder exhaust pipe. Well at least with a twin you can stumble home?? I assume this is not good news for the Japan Harley. Any one have this problem and what was the fix. I am going to try that crap they sell at the auto store for repairing cracked heads...it's cheap but not sure if it will work. Any help I do appreciated it.
JoeBro
2000 VN750
13 K
joebro is offline
post #2 of 3 (permalink) Old 07-17-2005, 08:25 PM
Loran in Npvl IL's Avatar
Re: Water out of exhaust..one cylinder
If it is only running on one cylinder, be sure the liquid flowing out is antifreeze and not gas. Is the anitfreeze getting less & less in the overflow bottle? Putting in stop leak can clog up important coolant passages so make sure it is a coolant leak before using it.
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
post #3 of 3 (permalink) Old 07-23-2005, 09:03 AM
Forum Faciliator
Red Baron's Avatar
Without more information on the bike, year, how much ridden etc, we don't have much to go on. But Check your battery, most of the time the reason for firing on one cylinder is low voltage. You are using seafoam, right? Also check plug wires, boots for cracking arcing. Right side plug has a tendency to arc against the throttle cables. Check wires to coils make sure they are clean and tight connections. Check your two grounds, make sure they are clean and making good contact. Check your battery connections, etc.. So start with this and then if that does not resolve the problem, give us more details.
Red Baron
Binghamton, NY
Alright Already, Lets Ride!!
Red Baron is offline
