Antifreeze leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 02-07-2016, 01:59 PM Thread Starter
Antifreeze leak
Got a leak from where the coolant downpipe goes into the motor. Tried replacing the o-ring but it doesn't seem to work. As soon as I start her up and pours out. Hoping I didn't damage anything. Anyone have a clue what to do?
post #2 of 4 (permalink) Old 02-07-2016, 02:03 PM
calebj's Avatar
Are you sure the o ring is fully seated? I had a time getting it to drop into the slot. Mine was pouring initially, but once I got it seated it stopped completely.
calebj is offline
post #3 of 4 (permalink) Old 02-07-2016, 02:28 PM Thread Starter
Thought it was seated properly. I tried it a few different times and even added an extra one at one point. Anyway I could of bent something in there so it doesn't seat properly?
post #4 of 4 (permalink) Old 02-07-2016, 02:42 PM
Make sure the tube and the hole is clean, the steel/aluminum together creates corrosion.
Helps to add a dab of grease around the o-ring/tube, prevents corrosion and helps seal.
