Shift Shaft Oil Leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 01-26-2016, 05:04 PM Thread Starter
Recently replaced magneto, stator and left engine covers. DID NOT replace the shaft seal in cover. Can it be replaced without removing the engine again?
Scubawerx--
Underwater Search, Salvage and Recovery Diving
Scubawerx is offline
post #2 of 11 (permalink) Old 01-27-2016, 11:55 AM
calebj's Avatar
I believe it's actually supposed to be replaced with the engine in place. Just pry it out and slide the new one on.
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #3 of 11 (permalink) Old 01-27-2016, 05:39 PM Thread Starter
Thanks for the response. I've seen that done on dirt bikes with engine in place, just didn't want to damage anything.
Thank you again.
Scubawerx--
post #4 of 11 (permalink) Old 01-27-2016, 08:45 PM
Just be careful not to mung up the shift shaft getting the old seal out.
dommie67 is offline
post #5 of 11 (permalink) Old 01-27-2016, 10:24 PM
Yup on that.the whole motor has to come apart to replace the shift shaft
post #6 of 11 (permalink) Old 01-28-2016, 09:49 AM
vulkan's Avatar
OleDirty...hope your joking.Some on here might actually be looking for "serious" help...be a shame if they really removed the engine for no reason when that seal goes in just fine without removing the entire engine.
vulkan is offline
post #7 of 11 (permalink) Old 01-28-2016, 10:56 AM
calebj's Avatar
You might want to read his post again. It -was- serious help. If you screw up the shift shaft doing a seal replacement, the engine has to come out and be torn open to repair it.
1999 EN500 32k
calebj is offline
post #8 of 11 (permalink) Old 01-28-2016, 11:33 AM
Sorry was talking about messing up the shifter shaft.didn't mean to get you worried.that's why I quoted the post I was referring to and said shifter shaft and not seal.sorry for any confusion.
post #9 of 11 (permalink) Old 01-28-2016, 07:39 PM
rev it up's Avatar
is this the seal in question here ?,,just im about to tackle changing mine too.
Name:	vn750 bitarrow.jpg
AGEING IS INEVITABLE,,MATURING IS OPTIONAL
VN 750 A8 1992.
27000 miles.
Imported from California
to UK in 1996.
New for 2012.
new filters(foam type)
replacement shocks(MDI)
Iridium plugs.
AGM battery(platinum)
brake pads(Kyoto)
(All on and running)
rev it up is offline
post #10 of 11 (permalink) Old 01-28-2016, 08:55 PM
That's the clutch linkage where the cable hooks to. The shifter shaft is on the bottom front left of the motor
