Won't stay running - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 10-30-2015, 08:08 PM Thread Starter
Won't stay running
My son-in-law has left his 2003 VN750 in my garage for several months with the petcock on and fuel in the tank. We have drained the tank and replaced the petcock with a non-vacuum model. We cleaned the tank and put seafoam in it with the new fuel. Now it will start but when the fuel in the carb is spent the engine dies. Is this something in the lines or do we have a vacuum issue?
smnoodleman is offline
post #2 of 4 (permalink) Old 10-30-2015, 08:20 PM
rsavant's Avatar
Have you confirmed there's fuel getting to the carbs? After it dies open the bowl drains and see if there's fuel in the bowls. You could also remove the lines from the petcock and see if fuel flows out.
"Katie"
2002 VN 750, stock except for accessories
Mustang seat
Super Bright LED brake strobe on trunk
About 25k miles
All drive train maintenance performed, drive shaft coupler replaced
Way more experienced at pulling VN 750 carbs than I ever wanted to be.
TOC ACCT rebuild kits installed
Pick up coil mod
Cooling system flushed, refilled with fresh coolant
Petcock rebuilt
VN sold, current steed Honda ST 1300
rsavant is offline
post #3 of 4 (permalink) Old 10-30-2015, 08:36 PM
2000 VN 750 Senior Member
You say it will start. How is the fuel it initially starts on get into the carbs? My point is that fuel must be getting there through the petcock and the fuel lines. Do a search on POOGS and the ways to fix/prevent that. Also do a search on cleaning your fuel cap vent system. You could pull the fuel lines at the carbs once it stalls and see if the fuel is flowing but I would guess it is. Let us know if you discover anything after checking those things.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is online now
post #4 of 4 (permalink) Old 10-30-2015, 08:39 PM
Could also be on the other end of the spectrum and may be flooding out.check the spark plugs to see if they're wet.the float bowl needles may be dirty.look up Wolfie's backblow method.it should be a sticky in the carb section.
