White Smoke from both exhaust pipes and front of bike... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 10-16-2015, 03:35 PM Thread Starter
VulcanMatt's Avatar
Started my 1992 up today and after about 15 seconds of warming up white smoke came from both exhaust pipes and when I shut it down some smoke started coming from the front of the bike (somewhere behind where the air filter assembly is). Any ideas?
VulcanMatt is offline
post #2 of 9 (permalink) Old 10-16-2015, 05:12 PM
did it smell sweet (like antifreeze), or any other distinctive smell?
michiganteddybear is offline
post #3 of 9 (permalink) Old 10-16-2015, 05:15 PM
Condensation, raw fuel, blown head gasket.
What color is the oil?
post #4 of 9 (permalink) Old 10-16-2015, 09:30 PM Thread Starter
VulcanMatt's Avatar
It had sort of a bitter smell to it...perhaps like anti-freeze, yes.
post #5 of 9 (permalink) Old 10-16-2015, 09:31 PM Thread Starter
VulcanMatt's Avatar
No condensation
Not sure about the blown head gasket.
Oil looks ok.
post #6 of 9 (permalink) Old 10-17-2015, 01:45 AM
Pull a spark plug from each cylinder, see if the plug is washed clean or has coolant on it.
Check for leaks in hoses and radiator.
post #7 of 9 (permalink) Old 10-17-2015, 10:04 PM
Mod
Birdhunter02's Avatar
Mine would do that on cool mornings.
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is offline
post #8 of 9 (permalink) Old 10-18-2015, 01:53 PM
X2 ,mine did too
post #9 of 9 (permalink) Old 10-21-2015, 03:18 PM
Pilgrim
Mine starts and runs a few minutes until it gets up to running temp and then starts to smoke from both pipes as well.
Although it having set for several years, after rebuilding the carbs before starting it, I poured automatic trans fluid into the cylinders, let it set a couple of days, then added more before finally turning it over with the plugs out. It shot the ATF out both sides but I figure sent some out of the exhaust valve as well. When I finally fired it up, it of course smoked like hell for a bit but then cleared up.
I figured that this smoking once warmed up now was just some of the ATF that had soaked into the baffles vaporizing once the mufflers get hot. Thing is, I drove it past that point till it quit smoking again a couple of times thinking that should have been the end of it. Well, it is still doing it.
I am now beginning to wonder if there is something else wrong.
TheDV8
"Theoretically what we really need here is a neutron flux high enough to bypass the gaps of instability."
A6ULdv8 is offline
