micro temp clock - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 10-14-2015, 08:46 AM Thread Starter
johnoni's Avatar
micro temp clock
Hi all, I have recently installed a micro temp clock on the bike. Problem is, Before I installed it the temp gauge was showing a good reading, not running hot etc. Since I have installed the micro temp clock it goes into the red. Is there anyway to remedy this, something I can do to calibrate the clock etc to bring it back into normal range.
Thank you
johnoni is offline
post #2 of 6 (permalink) Old 10-14-2015, 08:52 AM
calebj's Avatar
Got a link to the unit you installed?
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #3 of 6 (permalink) Old 10-14-2015, 09:07 AM Thread Starter
johnoni's Avatar
johnoni is offline
post #4 of 6 (permalink) Old 10-14-2015, 09:19 AM
My guess, the stock temp sender does not match the new gauge.
Did the gauge come with any specs to show what ohms it needs on the sending unit? I do see it comes with no wiring diagram.
post #5 of 6 (permalink) Old 10-14-2015, 09:33 AM
calebj's Avatar
Just re-read the OP. Are you saying that the stock gauge now goes into the red after you've added the auxiliary gauge?
1999 EN500 32k
calebj is offline
post #6 of 6 (permalink) Old 10-15-2015, 05:36 PM Thread Starter
johnoni's Avatar
No just the new clock. Didnt come with anything, wiring diagram or nothing. Can Anyone recommend a mini/micro temp gauge that I could fit without to much messing around,Send me a link. Thank you.
johnoni is offline
