is clymer wrong - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 10-01-2015, 12:15 PM Thread Starter
is clymer wrong
am i thick or what ? i am rebuilding my vn750 engine and when i read the clymer manual it say when counting the 38 links count up the right hand side for the front and the left for the rear there is a caution not on page 165 for the front cyl and page 172 for the rear cyl should this be the other way round ? i know we have different meanings for the same words in the uk but i am sure left and right are the same
trev uk is offline
post #2 of 5 (permalink) Old 10-01-2015, 04:47 PM
JM2001's Avatar
If facing the front cylinder from the left side of bike you would count up on the left side. If facing the rear cylinder from the right side of the bike you would count up on the right side.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 5 (permalink) Old 10-01-2015, 06:04 PM Thread Starter
i know your right jm2001 but the clymer manual reads the other way round so is it wrong
trev uk is offline
post #4 of 5 (permalink) Old 10-02-2015, 08:03 AM
JM2001's Avatar
If you download the VN750 manual from here you will see the Kawasaki specs on page 4-18. I would do what Ma Kaw says to do.
Link to manual
https://www.vn750.com/forum/11-vn750-...%2A%2A%2A.html
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #5 of 5 (permalink) Old 10-02-2015, 08:58 AM
Haven't dealt with this timing chain yet, but I will say I've found mistakes in some paperback manuals before. One had valve adjustment specs mixed up between two different engines, so you have to be careful.
Definitely look at the manual in the link.
