Ticking noise - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 09-26-2015, 05:42 PM Thread Starter
Ticking noise
The bike is making a ticking noise. It's pretty steady but isn't there as much when the engine is warm. I took it in to the local motorcycle shop for a diagnosis, they said they think it's coming from the head cylinder and think it might be a bad valve? But as I have looked and it seems like Vulcans have this issue a lot and people say it's the ACCT? I don't know what that is? Is that what they are talking about in the head? Has anyone else had this issue with their bike? Was it simple to fix? What's do you guys think?
Connorcc10 is offline
post #2 of 8 (permalink) Old 09-26-2015, 06:25 PM
Just search ACCT on the site and you will find all the info you need. Yes it is the ACCT. You can convert it to manual or buy manual tensioners, depending on your wrenching skills. Easy fix.
post #3 of 8 (permalink) Old 09-26-2015, 07:06 PM
Look in the Vulcan verses
post #4 of 8 (permalink) Old 09-26-2015, 07:33 PM
Also look up the Grambo trick
post #5 of 8 (permalink) Old 09-26-2015, 08:06 PM
ticking can be the ACCT's, but one thing to think of checking, the vacuum petcock can tick as well. mine does. no effect on operation or performance, its just the valve in it opening and closing. the petcock only gets vacuum signal from one carb, so it pulses with the intake stroke.
michiganteddybear is offline
post #6 of 8 (permalink) Old 09-27-2015, 01:52 AM
Drove me nuts for months until i found it.
post #7 of 8 (permalink) Old 09-29-2015, 07:23 PM Thread Starter
Does the Vulcan have automatic adjusting valves?
post #8 of 8 (permalink) Old 09-29-2015, 08:01 PM
Hydraulic lash adjusters, no adjustment.
More common to be the acct, but sometimes valves stick, or rarely a lash adjuster can fail.
