Coolant Leak - Mechanical Seal?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 09-20-2015, 05:51 PM Thread Starter
93VN750's Avatar
Ok, I have taken the cover off twice now to find out why my coolant is coming out of the weep hole in the bottom of the case almost as fast as I pour it in.
Here is picture of the mechanical seal installed. Is there anything wrong with how it is put it?
Where does the 9mm oring go with respect to the impeller and shaft?
Needs some help please.
Thanks,
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 2 (permalink) Old 09-20-2015, 07:57 PM
JM2001's Avatar
Did you knock the mechanical seal into the hole with a bearing driver? It may not be seated properly.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
