Must do both ACCT's? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 09-17-2015, 01:18 AM Thread Starter
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Perhaps this is somewhere and I just plain didn't notice it. When doing an ACCT to MCCT conversion, must you do both cylinders or is it ok to just do the one sounding off? Part of me says it shouldn't matter but the other part says if you do one, do them both.
Chris and Shim is offline
post #2 of 10 (permalink) Old 09-17-2015, 08:35 AM
only have to do the offending one, but the other will likely fail as well, so I would recommend doing both
michiganteddybear is offline
post #3 of 10 (permalink) Old 09-17-2015, 08:48 AM
You will need a spacer and a longer bolt for the coolant reserve tank
post #4 of 10 (permalink) Old 09-17-2015, 11:02 AM
How do you guys feel about the TOC spring repair kit for the stock ACCT's? I would like to keep the bike as stock as possible (except for the V&H Cruzer pipes I just put on).
dommie67 is offline
post #5 of 10 (permalink) Old 09-17-2015, 11:49 AM
Mod
Birdhunter02's Avatar
They will work, but fail again. With the mcct your done.
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is offline
post #6 of 10 (permalink) Old 09-17-2015, 03:52 PM Thread Starter
Thanks for the answer. My front one was making "that noise" every so often. Once I get it running again that will be an almost immediate swap. Thankfully its the easier one to attend to.
post #7 of 10 (permalink) Old 09-26-2015, 09:07 PM
Concert connoisseur
wib714's Avatar
I only did my front 25000 miles ago, all is good and never had too adjust. toc spring broke on me and almost stranded me!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #8 of 10 (permalink) Old 09-27-2015, 12:11 AM
Really wanna try this but I'm afraid I'll just jack it up haha.
post #9 of 10 (permalink) Old 09-27-2015, 07:52 AM
What do you mean it almost left you stranded? How did you know it broke and how did you get home?
dommie67 is offline
post #10 of 10 (permalink) Old 09-30-2015, 08:55 PM
Concert connoisseur
wib714's Avatar
when it broke it stated clacking really loud at at idle and low rpms, rev it up to about 2500+ and it would smooth out, the new spring was only in for a few hundred miles. I drove it home 30 miles keepin the rpms up til I got home. took the acct off and my new toc spring was in two pieces. went and bought the hardware and did the conversion and not a problem or rattle since!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
