Mechanical Seal???? Bad install??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 09-06-2015, 06:24 PM Thread Starter
93VN750's Avatar
Putting my bike back together after a few years of down time.
I was adding coolant and it is pouring out the weep hole in the bottom of the case.
I had just replaced the mechanical seal prior to taking some time off from this project.
What could I have done wrong with the impeller and mechanical seal install causing this?
I already pulled the engine cover for access, just not sure how to proceed.
All thought, comments, suggestions are welcome and appreciated.
Also, where are we buying parts these days? I did use cheap cycle parts before.
Thanks,
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
