Oil leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-28-2015, 10:11 PM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
Oil leak
I just did a Tuxedo mod and stator replacement. I have developed several oil leaks. One is where the external oil line meets the rear cylinder. I have new copper sealing washers (from a set sold as brake system parts) but I'm afraid to over torque it and strip the bolt. Same with end with the sending unit in it. Then there's oil all around the bevel gear case. Parked on the center stand it drips along the left side and the seam running down the center of the motor. Any like culprits? Suggestions?
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #2 of 3 (permalink) Old 09-18-2015, 12:06 AM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
I'm going to try replacing the o-rings in the spark plug wells. Would it work to replace the copper sealing washers with rubber or neoprene washers? I don't know if it would be a tighter seal or if it would just blow out the rubber washers.
post #3 of 3 (permalink) Old 09-18-2015, 12:19 AM
If they are copper to begin with there is probably a reason
