Coolant Leak from Bottom of Engine - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 08-23-2015, 07:23 PM Thread Starter
93VN750's Avatar
As the subject states, I was filling the coolant system today and found a puddle under the bike. Coming out of hole shown in photo below.
Bike has no oil as just getting around to getting it running after several years.
I had replaced the water pump impeller last time I worked on it.
This looks like some kind of weep hole, I hope it doesn;t mean pulling the engine again.
Thanks in advance.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 2 (permalink) Old 08-24-2015, 10:07 AM
Crowley
crowley1027's Avatar
You must have missed something, that's the weep hole for the water pump. Means something isn't sealing right.
You don't need to pull the engine, just the exhaust and frame rail.
crowley1027 is offline
