coolant leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-16-2015, 01:13 PM Thread Starter
Question coolant leak
help! i found coolant in the intake on the front cylinder. are there coolant lines going to the carbs if so which ones are they? if not are we talking about a blown headgasket or a cracked head?
thanks for any info. oh yeah it is a beautiful 1995 vulcan 750 vn.
sniknah4567 is offline
post #2 of 5 (permalink) Old 08-16-2015, 02:09 PM
maybe a bad o-ring in the coolant lines?
post #3 of 5 (permalink) Old 08-17-2015, 10:58 AM
heaney750's Avatar
is the bike running? does it overheat? is it smoking?
heaney750 is offline
post #4 of 5 (permalink) Old 09-02-2015, 09:11 PM
I had a coolant leak in my front cylinder on the base gasket. If it's pooling up in the inside curve in between the front and the rear cylinder it's probably just the gasket that needs to get replaced. Expensive none the less but I wouldn't worry about the whole engine going bad.
mattdavis111 is offline
post #5 of 5 (permalink) Old 09-03-2015, 12:27 PM
And are you sure it's not leaking down from the cap or thermostat.
