Coolant leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-16-2015, 12:48 PM Thread Starter
johnoni's Avatar
Coolant leak
Was out on a run today and noticed that I have coolant leaking out of the cap at the expansion bottle. Overfilled? or something different. Answer on a postcard to VN750s are nutty but fun. Cheers.
johnoni is offline
post #2 of 3 (permalink) Old 08-16-2015, 02:02 PM
It shouldn't leak out of the cap. The bottle has an overflow tube and excess coolant should escape through there. Maybe it's clogged?
If you hadn't added coolant recently and it started spitting it out, chances are you are low on coolant. It can get low enough to boil and purge coolant via steam/etc if the bike gets hot enough.
post #3 of 3 (permalink) Old 08-16-2015, 02:58 PM
Crowley
crowley1027's Avatar
The cap has a rubber grommet on the inside. Check to see if it is there.
Either way, something got too hot.
crowley1027 is offline
