Small hole in front cylinder head - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-30-2015, 09:37 AM Thread Starter
Question Small hole in front cylinder head
Hi, what is this small hole? When the engine is hot, there is dripping oil out of it.
It is at front of the front cylinder head, below the BREATHER JOINT (Ref#92005) (Part#14067-006)
ihlebek is offline
post #2 of 4 (permalink) Old 07-30-2015, 01:14 PM
That is the wheel hole for your front deep well spark plug.
if oil is leaking from it, you have a bad oring. It's an easy fox. Your rear axle nut should fit it & it just spins out. Replace oring & reinstall.
post #3 of 4 (permalink) Old 07-30-2015, 10:14 PM
Concert connoisseur
wib714's Avatar
x2, heres a thread on it!
https://www.vn750.com/forum/showthread.php?t=57417
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #4 of 4 (permalink) Old 07-31-2015, 05:03 PM
wheep
Tags
cylinder head , hole , leak , oil
