changed out temp gauge - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 07-24-2015, 04:20 PM Thread Starter
johnoni's Avatar
I have recently changed out the OEM temp gauge to an of the shelf mini one.
Problem is, when the bike get to temp the needle goes all the way to the red. Is there a running temp figure that the vn750 runs at? I have looked in haynes guide etc and cant find one as shop i bought this temp gauge from has asked for this in an effort to diagnose the problem. Thanks.
johnoni is offline
post #2 of 5 (permalink) Old 07-24-2015, 05:46 PM
JM2001's Avatar
Per manual: Thermostat begins to open between 176- 183 degrees. Full open at 203 degrees. Bike should run somewhere in between that range is my thought, probably 180-190
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 5 (permalink) Old 07-24-2015, 05:52 PM
that's what I would expect.
are you using the stock oem sender? the difference in resistance could account for the reading error.
michiganteddybear is offline
post #4 of 5 (permalink) Old 07-25-2015, 04:53 AM Thread Starter
johnoni's Avatar
Yes, using the stock OEM sender. Is it possible to change this out? And thanks for the replies.
johnoni is offline
post #5 of 5 (permalink) Old 07-25-2015, 08:01 AM
The sensor and temp gauge need to matched together. As stated previously, the resistance reading of the aftermarket gauge may be different than the stock sensor.
'99 VN750, all stock
performed driveshaft maintenance
checked the ACCT using the Grambo Trick
Sycned carbs with flow meter
Yuasa YTX14AHL-BS AGM Battery
NGK DPR7EIX-9 Irridium Spark Plugs
vulcan1999 is offline
