Fan not turning on - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-21-2015, 11:22 PM Thread Starter
Fan not turning on
So I was working on my bike and the frail copper tab on the side of my radiator which from my research looks to be a water sensor part #92066-1183 broke off, so now a cable from the wiring coming from the trunk of cables that the fan is with is not plugged into anything. I started my bike and watched the temp climb and climb until it shut off because off temp issues and the fan never kicked on. Im wondering if this tab on the water sensor (the nut that it was connected to appears to be fine) controls the fan and tells it when to kick on, I would like to know before I go spend money on one and have it not work
99problems&vulcanis1 is offline
post #2 of 6 (permalink) Old 07-21-2015, 11:31 PM
Maybe solder?
post #3 of 6 (permalink) Old 07-21-2015, 11:47 PM Thread Starter
Maybe solder?
That was my first thought.. I tried it and cant get it to grab since it broke off all the way back on the rounded part.
My next option is to either bypass it all together and have it always on or get this water sensor if I determine that is the issue..
post #4 of 6 (permalink) Old 07-22-2015, 12:27 AM
What about a switch?
post #5 of 6 (permalink) Old 07-22-2015, 12:32 AM Thread Starter
Not sure what you mean? Hook it directly to the battery and put a switch in?
post #6 of 6 (permalink) Old 07-22-2015, 01:00 AM
That's one way.the sensor is basically a switch as well.gets to temp the circuit closes.use a switch instead of the sender to close the circuit
Tags
fan , fan switch , radiator , water
