Starter removal? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-07-2015, 04:38 PM Thread Starter
Starter removal?
I've drained the oil disconnected the battery undid the positive cable from starter and removed both bolts but can't get it out is there anymore bolts to remove other than the two by the cable or is there a trick to getting it out? Thanks again you guys are lifesavers!!!!
Nodraws is offline
post #2 of 6 (permalink) Old 06-07-2015, 07:09 PM
JM2001's Avatar
Rubber mallet or wooden hammer. Tap the top left of the motor and push the motor down and to the left. Keep taping it and tilting it to the left.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 6 (permalink) Old 06-08-2015, 07:44 AM Thread Starter
Thanks I was afraid of breaking the bolt hole off the starter
Nodraws is offline
post #4 of 6 (permalink) Old 06-09-2015, 01:33 AM
You can also use a screwdriver between the crankcase and the starter and pry gently it'll pop out
mrseedsower is offline
post #5 of 6 (permalink) Old 06-09-2015, 09:41 AM
yep just pry that sucka off
post #6 of 6 (permalink) Old 06-10-2015, 12:40 PM
I didn't have that much trouble when I rebuilt mine. It is a pretty snug fit with the o-ring on there.
it should come straight out. I wouldn't angle it too much.
