Degoated today--center stand question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-14-2005, 08:30 PM Thread Starter
Jaybird's Avatar
I succesfully de-goated my 2003 today and used flexible tubing to connect the headers to the mufflers. The job was fairly simple. I was a little surprised how much the mufflers moved when the job was done.
Anyways, the center stand now hits the left side heat shield. Does anyone have a solution? I do not want to remove the center stand so I assume some sort of bracket will be needed.
Jaybird
2003 VN750
Saddleman seat
V-force windshield
Willie & Max saddle bags
Jaybird is offline
post #2 of 3 (permalink) Old 05-14-2005, 08:40 PM
Re: Degoated today--center stand question
IIRC, I used a large heavy grommet. Cut a slit, and taped it to the centerstand so it would cushion the bump into the left frame rail....
jm1515 is offline
post #3 of 3 (permalink) Old 06-11-2005, 07:13 PM
jabird, Will you tell me how you fixed the problem with center stand?
JIBARO RIDER is offline
