Changing oil for the first time... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-11-2005, 11:08 AM Thread Starter
1992 Vulcan 750
tampametal's Avatar
Send a message via AIM to tampametal
I bought the recommended filter and oil from Walmart. First I see the st7317 is smaller than the original and what are the steps for changing the oil properly.
Thanks Jake
Jake
Lutz, Florida
1992 Kawasaki Vulcan 750
Kuryakyn ISO Grips
Vance & Hines Exhaust
Corbin Custom Seat
Custom Billet Skull Flame Mirrors
Willie & Max Saddlebags
De-goated
Bike Photos
tampametal is offline
post #2 of 6 (permalink) Old 05-11-2005, 09:39 PM
Cool Re: Changing oil for the first time...
jake; return the st- 7317 filter for a st-6607 @ walmart. i bought the 15w-40 shell rotella under $7.00 gal. plus one [email protected] around $1.70 .drain and re-fill with new filter is 4 liters .i filled filter with clean oil . total of 1 gal.6oz. with engine running on center stand oil level will be between low and hi mark in sight glass. also be sure to remove and clean screen filter.on left side of engine. may take 10 to 30 sec.for oil light to go off after start up. drive safe ken smith in penfield , new york
kas750 is offline
post #3 of 6 (permalink) Old 05-12-2005, 12:18 PM Thread Starter
1992 Vulcan 750
tampametal's Avatar
I used the 7317 this time but will loose it next change. It is definately quite a bit smaller. I also noticed that the guy that had the bike before be was removing the 17mm oil drain bolt with a set of vice grips
If anyone has a link where to get a replacement I would be very pleased.
Jake
Jake
Lutz, Florida
Kuryakyn ISO Grips
Corbin Custom Seat
De-goated
Bike Photos
post #4 of 6 (permalink) Old 05-12-2005, 03:40 PM
Loran in Npvl IL's Avatar
The engine should NOT be running when the oil level is checked
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
post #5 of 6 (permalink) Old 05-12-2005, 08:04 PM
Search Goddess
Dianna's Avatar
Loran is right.. When the engine is running you shouldn't see anything in the sight glass. Run engine to get the oil through your system then turn engine off, let it "settle" then check with the bike level. You should see just a small bubble at the top of the glass. Anything less, add a bit and cycle repeat procedure.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #6 of 6 (permalink) Old 05-16-2005, 09:42 PM Thread Starter
1992 Vulcan 750
tampametal's Avatar
Thanks for all the help guys.... Just waiting for my V&H Cruzers to get here.
Jake
Lutz, Florida
Kuryakyn ISO Grips
Corbin Custom Seat
De-goated
Bike Photos
