Engin Instalation Questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 08-25-2014, 12:37 PM Thread Starter
NYSGSP's Avatar
I pulled my motor out and the carbs were removed per a friends suggestion
can the carbs be installed before I put the motor back in?
and what is the best way to install the motor ?
it took 2 of us to lift and renmove the motor
I don't see it being easy to manually lift the engine and get her in place.
Any suggestions will be greatly apreciated.
Thanks
John
NYSGSP is offline
post #2 of 20 (permalink) Old 08-25-2014, 12:52 PM
GloryRider's Avatar
Hey John,
It's not easy to do by yourself, but it is possible! Two people will definitely make the job easier... I used a floor jack with wheels, but it takes some finagling to get it positioned right... did you take off the bevel gear housing? If so, it'll be a lot easier to get back into place. Use the floor jack to maneuver the engine into place, and then use the top rear engine mount bolt first (don't forget the round spacers!) to hold it in place until you can get the rest of the bolts in.
Take your time and go slow... be careful not to break the shift rod sticking out on the left side. I also would recommend not installing the carbs until you have the engine back in, unless you haven't done an earshave, and have to re-install the surge tank.
Hope that gets you started...
-- Matt
GloryRider
Atlanta, GA
Current Ride: 1995 Vulcan 88 (1500A9)
Purchased Dec. 2014
approx. 6,800 miles
Previous Bike: 2000 VN750 "Glory"
With homemade stator
Details on stator build here
"Four wheels move the body. Two wheels move the soul"
"You live more in 5 minutes on a bike like this going flat out than some people live in their lifetime." - Burt Munro
GloryRider is offline
post #3 of 20 (permalink) Old 08-25-2014, 05:57 PM Thread Starter
NYSGSP's Avatar
thanks Matt
I was wondering if the carbs could go on before installing the motor as from what I can tell it is going to be fun getting the carbs on later
but from what I read on the forum the carbs go in ok
with a little patience
NYSGSP is offline
post #4 of 20 (permalink) Old 08-25-2014, 06:47 PM
Okiebezer's Avatar
A little patience and a lot of elbow grease, mixed with some frustration. One thing to make sure of is to align the boots that connect the carbs to the cylinders. There is a particular way they must be for everything to seat properly. I've only had mine off once to rebuild and rejet, did the earshave at the same time. Just seemed easier that way.
Here is a thread that may help you a bit.
https://www.vn750.com/forum/showthread.php?t=16907
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #5 of 20 (permalink) Old 08-25-2014, 07:05 PM
Concert connoisseur
wib714's Avatar
I've removed mine twice with carbs intact and put it back in once so far, bevel gear disconnected. motor on a floor jack and the bike on a scissor jack. alot of wiggling and it helped to turn the handlebars while doing it! and I did it alone, a second person would have been awesome!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #6 of 20 (permalink) Old 08-25-2014, 07:21 PM Thread Starter
NYSGSP's Avatar
Wib
could you explain the one man 2 jack process works
the other tread I read said 2 jacks 1 in the rear of engine and 1 in the front
my floor jack did not go low enough we actually lifted and twisted the engine out.
I do not want to try lifting her back in
your 2 jack set up sounds better
Thanks
John
NYSGSP is offline
post #7 of 20 (permalink) Old 08-25-2014, 08:33 PM
emtdon's Avatar
If you put the center stand on a 2x6 it will give you a little more height to use a floor jack. If you have a smaller jack. Once you get it under a ratchet strap will help keep it from falling off the jack. I just centered the engine on the jack without a board under it. just be careful so it doesn't fall off sliding it in place.
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #8 of 20 (permalink) Old 08-25-2014, 08:40 PM
I did a stator change with engine pull and left the carbs on. No big deal.
post #9 of 20 (permalink) Old 08-25-2014, 08:46 PM
I used a motorcycle jack under the motor and the bike leaned up on a wal.carbs were on .
post #10 of 20 (permalink) Old 08-26-2014, 10:07 AM
GloryRider's Avatar
I was able to do it by myself using the floor jack, and lifting the frame up on jack stands... I ended up straddling the bike to keep it from falling over, while I reached down and maneuvered the engine into place...
GloryRider
Atlanta, GA
Purchased Dec. 2014
approx. 6,800 miles
