Oil leak: another common issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 06-30-2014, 04:25 PM Thread Starter
Concert connoisseur
wib714's Avatar
again while my motor is out I thought I'd post some decent pics of another common issue: oil leak in the front cylinder
if the front of your engine is covered in oil from the exhaust down this could be why, in the pic below is the front of the motor, you see a little tube sticking out with a tiny weep hole directly below it. this is probably where the oil is coming from.
closer pic
It is a simple fix, you just need to replace the orings in your spark plug wells. pictuerd below
To remove this you need to remove your rear axle nut to use as a tool
The part numbers for the orings can be found on most sites under the "cylinder head covers" diagram but here are cheapcycleparts number 92055-1255 and 92055-1272
as always, hope this helps!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #2 of 14 (permalink) Old 06-30-2014, 04:35 PM
200% senile
Texas's Avatar
Thanks for the heads up and the info on how to fix it, much appreciated!
1996 VN 750
2007 Vulcan Mean Streak SE
When I was younger I was afraid I'd die riding. Now that I'm old and falling apart, I'm afraid I won't.
Texas is offline
post #3 of 14 (permalink) Old 06-30-2014, 04:45 PM
wow.
wmsonta is offline
post #4 of 14 (permalink) Old 10-29-2014, 10:17 PM
post #5 of 14 (permalink) Old 04-22-2015, 10:02 PM
This helped so damn much, glad I noticed the weep whole by sticking my phone in a spot u couldn't see them checking here, was about to start trying to replace rocker cover gaskets or valve cover or lower cylinder head gasket, this hero a long headache to go with the learning curve
pez46 is offline
post #6 of 14 (permalink) Old 04-23-2015, 05:52 PM
nicely done Wib......good photos always help explain things better.
this should become a sticky IMO
post #7 of 14 (permalink) Old 04-23-2015, 05:59 PM
Good job. I guess we can keep you around a little longer lol.
post #8 of 14 (permalink) Old 04-23-2015, 06:23 PM
JM2001's Avatar
Good post and informative. Should be a sticky.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #9 of 14 (permalink) Old 04-25-2015, 02:19 PM Thread Starter
Concert connoisseur
wib714's Avatar
I thought it was a sticky, oh well. I did this write up long after I replaced my orings so if anyone takes their spark plug wells out please add some pics of the orings on the wells! I didnt want to go through the trouble although it is pretty simple to remove my axle nut again and pull my wells out for the write up.
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #10 of 14 (permalink) Old 04-25-2015, 02:50 PM
Common issue? Really?
