How can i take the baffles completely out - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-19-2014, 05:48 PM Thread Starter
Gt an 86 vn750 is there anyway to take the baffles out of the exhaust with out cutting anything off..i see the 2 welds near the end of the exhaust. If i drill them out will hat free it up to take out or is it as wide as the expanded part?
Little00gt is offline
post #2 of 7 (permalink) Old 06-19-2014, 05:54 PM Thread Starter
Nevermind figured it out!
post #3 of 7 (permalink) Old 06-19-2014, 07:06 PM
Can you share? In case others have the same question
Old Bike: 2006 VN750 - Sold
eusjma is offline
post #4 of 7 (permalink) Old 06-19-2014, 07:23 PM
I have a set that was gutted. If you want them let me know.
They look OK other than a patch on the inside where they had a hole before I removed the baffles.
post #5 of 7 (permalink) Old 06-20-2014, 06:36 PM Thread Starter
It was actually pretty easy to do..i took both heat shields off, then loosened the clemps on the exhaust(clamps closed to the rear of the exhaust). Next loosen the the bolts on both sides holding the exhaust to the frame(they r nut and bolt and right by te center of the rear wheel on both sides..the rear of the exhaust should now slide off, u may have to wiggle them to get them off all the way. After u have them off u will have to drill out 2 welds right near the end of the exhaust tips. Then u will have to bust out the baffle on the front side of the part u took off and after that u can use a piece of re-bar and and hammer to bang out the cylinder shapped baffle that is pretty much the length of the pipe u r holding..it may take a beating to get them out but they will come out eventually them reverse ur steps to put the pipes back on.
post #6 of 7 (permalink) Old 06-21-2014, 08:08 AM
I left the screen in the front of the muffler in place and pulled everything out the back.
post #7 of 7 (permalink) Old 06-21-2014, 09:58 AM Thread Starter
I wasnt able to pull thats the only reason i punched a hole in it
