Overbore worth it? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 06-17-2014, 11:37 AM Thread Starter
Crowley
crowley1027's Avatar
Overbore worth it?
Just got a newish rear jug for 30 dollars shipped. Nice!
Before I shop for Pistons and rings, should I consider boring out 1mm? I understand that technically there will be more power but is the increase noticeable? Is it worth spending the money on the machine work?
crowley1027 is offline
post #2 of 11 (permalink) Old 06-17-2014, 11:51 AM
IMHO not really. You really won't notice it. The only reason to do it is if your cylinder walls are jacked up.
post #3 of 11 (permalink) Old 06-17-2014, 12:21 PM
X2, BTW you do not bore this assembly oversize. You hone it oversize.
wmsonta is offline
post #4 of 11 (permalink) Old 06-18-2014, 02:40 AM
for once i agree with you wm
if you think it needs to be honed just give it a light and quick hone then mic it out and you will probably still be within specs for standard size rings
post #5 of 11 (permalink) Old 06-18-2014, 06:30 PM Thread Starter
Crowley
Got it. The new jug has been ball honed already, so I only need a honed rear or a rear jug and ball honer
post #6 of 11 (permalink) Old 06-18-2014, 07:07 PM
berzerker1982-BL's Avatar
I am wondering how big can you go?30 40 60 over?
berzerker1982-BL is offline
post #7 of 11 (permalink) Old 06-18-2014, 07:08 PM Thread Starter
Crowley
As big as you want before you run out of sleeve material - but don't expect it to run long
post #8 of 11 (permalink) Old 06-18-2014, 11:50 PM
I say bore it out to a VN800 bore, and slap them 800 pistons in....then run her up to like 110mph....see how she runs....
post #9 of 11 (permalink) Old 06-19-2014, 12:59 PM
I AM NOT SURE, but I believe you can get cylinder kits for 1mm. .039". The only available I have heard of and common among modern stuff.
wmsonta is offline
post #10 of 11 (permalink) Old 06-19-2014, 09:46 PM
Thanks fer using that phrase...more should...kudos to to....
