exhaust changes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-16-2014, 10:39 PM Thread Starter
exhaust changes
So I am thinking of removing the back slip on mufflers just behind the chamber muffler. Do I need to rejet the carbs for this? Or will I be okay? Have an 03 vn750a
sgtjennings1987 is offline
post #2 of 7 (permalink) Old 06-16-2014, 10:52 PM
Chasin' the blacktop
Spencer1's Avatar
Without the backpressure from the mufflers your engine is probably going to run poorly. The few people I've read about here who went to straight pipes extended the pipes way back to build up a bit more backpressure.
North Georgia
Spencer1 is offline
post #3 of 7 (permalink) Old 06-16-2014, 11:02 PM
dont run it without the muffs on there unless you want to burn your valves
you can as fool said put some straight pipes on that run out to the back of the rear tire and be safe
post #4 of 7 (permalink) Old 06-16-2014, 11:24 PM
Spencer1's Avatar
X2 I couldn't remember exactly why it was bad to run short straight pipes. Thanks new rider
North Georgia
Spencer1 is offline
post #5 of 7 (permalink) Old 06-17-2014, 02:40 PM
I am assuming the OP is talking about leaving the Goats Belly in place and running straight pipes from there back.
I personally believe that the Goats Belly produces all the back pressure you need, so I see no harm in drilling the baffles or running straight pipes from there back.
EDIT: the original question was weather he should re-jet......there seems to be debate on this forum if it is needed or not, so I cannot answere that question confidently.
post #6 of 7 (permalink) Old 06-17-2014, 07:39 PM
EDIT: the original question was weather he should rchancese-jet......there seems to be debate on this forum if it is needed or not, so I cannot answere that question confidently.
Three year Member Synopsis....
Ear Shave....No Rejet needed - nothing gained (ease of carb/engine pull only)
Ear Shave & Exhaust Change - Rejet - much gained
Looks only - Exhaust Change only - ? ? ?
Straight Pipes....... Long Exhaust past rear tire ..... OR burn exhaust valves....
.... & with or w/o goats belly....take your chances....
Members...is this accurate ?
wmsonta wmsonta is offline
EDIT:
PRECISELY:
Join Date: Jan 2013 Posts: 1,869 wmsonta will become famous soon enough
With out the muffs, I would re jet.
post #7 of 7 (permalink) Old 06-17-2014, 07:59 PM
wmsonta is offline
