86 vn750 missfire front cylinder - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-14-2014, 01:37 PM Thread Starter
So far i have changed the front coul pack out with a brand new oem coil pack, brand new NGK 7mm spark plug wires, brand new NGK iridium spark plugs. All of them to hopefully fix the missfire the front cylinder is having at low rpm when im starting to take off from a stand still..once im moving its fine...any thougths as to what it could be?
Little00gt is offline
post #2 of 5 (permalink) Old 06-14-2014, 01:54 PM
Probing in the dark here, but.....
Have you successfully cleaned all the contacts on the Ignitor connector plug ... ?
post #3 of 5 (permalink) Old 06-14-2014, 07:49 PM Thread Starter
Im gonna have to ask what an where that is? Lol
post #4 of 5 (permalink) Old 06-14-2014, 09:32 PM
The Ignitor is what provides the pulse signal for your spark plug coils.
Remove the plastic right side (body) cover (one screw/bolt) you will see it bolted to the backside (rear) of your battery box, the connector is easily accessible. Carefully remove (6 pin ? & 4 pin ?) connector(s), clean ALL contacts completely on connector plug and receptacles. Contacts should appear as new contacts when completed. . . . take your time.
Contact cleaner, light abrasive material, rubbing alcohol, pencil erasure's (sp ?) ...
you got the idea.....many methods available to clean contacts.
Reconnect connector ....start 'er up !
hth
post #5 of 5 (permalink) Old 06-15-2014, 10:17 AM Thread Starter
Thanks! I'm gonna do that right now!
