wondering about sparkplugs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 06-07-2014, 07:54 PM Thread Starter
berzerker1982-BL's Avatar
So while changing oiltoday i noticed. My spark plugs were loose and while tightining.i was afraid to tighten up too much just couldent feel them bottoming out. So i just tightened them up until. They felt tight and called it good.
How hard is it to strip the threads ? Was scared to tighten up too much....o and sorry for all the. Periods as the site dosent. Seem to like my phone....
berzerker1982-BL is offline
post #2 of 11 (permalink) Old 06-07-2014, 08:05 PM
Dr. Vulcanstein
jadabull's Avatar
The threads can and will strip if over torqued. I just snug them using only one hand on the ratchet. Don't quote me but I thing torque value for the plugs is around 14 ft/lbs
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #3 of 11 (permalink) Old 06-07-2014, 08:13 PM Thread Starter
I figured as much....i hand tightened them and then went around half a turn beyond that....
Stupid ? But say they get stripped is there a fix for that?
post #4 of 11 (permalink) Old 06-07-2014, 08:22 PM
Dr. Vulcanstein
jadabull's Avatar
Nope not stupid, lots of people hand tighten then give 1/4-1/2 extra turn. As far as a fix for striping the thread.....you'd probably have to get a used head unless you could re-tap (of course while the head was removed from the motor) the threads and use a larger plug but I would just buy a used head from someone here or fleabay for around $50.
Oh and I was slighty off on the torque value, it should be around 12 ft/lbs. Hope this helps.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #5 of 11 (permalink) Old 06-08-2014, 12:38 PM
Jada.....I believe the threaded part of the spark plug well can be removed and replaced.
part number 92066-1224 PLUG,CYLINDER HEAD
You use the rear axle nut (or equivilent) to remove the plug wells which have a seal behind them. This is the piece the spark plug threads into.....is it not?
post #6 of 11 (permalink) Old 06-08-2014, 01:58 PM
Dr. Vulcanstein
jadabull's Avatar
I don't think the op is talking about the plug retainers but where the plug actually screws into the head. The well sits around the plug the plug doesn't thread into the well. Sorry if I am not understanding you.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #7 of 11 (permalink) Old 06-08-2014, 05:05 PM
I believe Jada is right on what the OP was asking,. I would also advise a little anti-sieze on the plug threads to keep them from corroding to the aluminum head. I just tighten them with one hand and use it on the ratchet head with the handle sticking out.snug and a 1/4 seems about right.
post #8 of 11 (permalink) Old 06-08-2014, 05:47 PM
Yes. They are called Heli-coils.
Any well equipped shop can do this for you for less than buying all the needed tools yourself.
Might be a good idea to get yourself a torque wrench....
post #9 of 11 (permalink) Old 06-08-2014, 09:14 PM
Dr. Vulcanstein
jadabull's Avatar
Thanks KM, I want to check into these. I don't plan on stripping anything, but.......
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #10 of 11 (permalink) Old 06-09-2014, 01:42 AM
Ndr
I've used Heli-coils a couple of times with good success.
Ndr is offline
