Backfiring when letting off of throttle - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 06-07-2014, 11:46 AM Thread Starter
Does this mean im running too rich, too lean?
Little00gt is offline
post #2 of 24 (permalink) Old 06-07-2014, 11:54 AM
Probably not actual backfiring.
Is it popping when closing the throttle at low rpm or from highway speeds?
wmsonta is offline
post #3 of 24 (permalink) Old 06-07-2014, 03:18 PM
HowardLangston's Avatar
Have you done any mods to the bike? I recently did the earshave and V&H exhaust. I had the same issue and just had to adjust the air/fuel screws on the carbs.
HowardLangston is offline
post #4 of 24 (permalink) Old 06-07-2014, 06:24 PM Thread Starter
Yup popping at low rpm everytime i let off the throttle.. Do i fix that with the air/fuel screws on the carb like howard said?
post #5 of 24 (permalink) Old 06-07-2014, 06:26 PM Thread Starter
I just bought the bike a few weeks ago and discovered the guy that had it cut out the H pipe between the pipes and welded up the holes from that..thats the only mod that i know of
post #6 of 24 (permalink) Old 06-07-2014, 07:22 PM
I don't know the specifics with that exhaust mod, but I would turn the screws CAREFULLY all the way in and the start at two and a half turns out. This is the general guidelines the brains on this sight would suggest. I ended up with 3 turns on the front and 2.5 on the rear cylinder. This is a few threads on this kind of problem already. I would search for them and read them. FYI the screw for the front cylinder is on the left and rear on the right. It took me a while to realize this. Hope this helps.
post #7 of 24 (permalink) Old 06-07-2014, 07:30 PM Thread Starter
Thanks a bunch! Much appreciated!
post #8 of 24 (permalink) Old 06-07-2014, 09:05 PM
Yes, that will help. About the only thing that will. If you try to completely stop the popping, it will idle way to rich for my preference.
Have you coaster-ed or marbled yet?
Any exhaust leaks at the head?
wmsonta is offline
post #9 of 24 (permalink) Old 06-07-2014, 09:05 PM Thread Starter
Anyone got a pic of the screw for location.. I found the one on the bottow near the idle screw but i dont see the other one
post #10 of 24 (permalink) Old 06-07-2014, 09:13 PM Thread Starter
I dont know what either of thise things r or know how to do them until explained lol
