ok stupid ? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 06-01-2014, 08:07 AM Thread Starter
berzerker1982-BL's Avatar
ok stupid ?
How do i check the oil? Cant. Find a inspection window anywhere...
Sorry for the newbie ? ...
berzerker1982-BL is offline
post #2 of 11 (permalink) Old 06-01-2014, 08:11 AM
this cover is located just under the front bevel gear.
post #3 of 11 (permalink) Old 06-01-2014, 08:33 AM
JM2001's Avatar
The sight window is just below where the clutch cable engages the clutch shaft on the engine. Both are below where your oil fill plug is. Also by the kickstand.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 11 (permalink) Old 06-01-2014, 08:54 AM
2000 VN 750 Senior Member
One of the reasons you may not be able to find the sight window is because it has discolored over years of dirty oil and lack of proper care from previous owners. I would also recommend that you invest in an owners or shop manual. Questions are still welcomed with or without the manual. lol
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #5 of 11 (permalink) Old 06-02-2014, 05:32 AM
Ndr
Or, it may also be hard to see because the bike is on its kick stand? (the bike needs to be upright and level to check the oil level.
...Or there is possibly too much oil in there.
Ndr is offline
post #6 of 11 (permalink) Old 06-02-2014, 03:53 PM
Then sometimes you have to have someone rock it side to side to find the level. Or in my case I get my girl friend to look at the glass while I lean the bike toward her and away. Without leaning the bike it can really not show anything. When it's low on oil, you will see an obvious channel behind in the middle of the glass.
post #7 of 11 (permalink) Old 06-02-2014, 06:02 PM
Headbanger/Popes of Hell
ruger's Avatar
or maybe.......your bike is just that dirty and need a good bath! lol
it's possible that the widow in covered by dirt, grease/oil and grime and just needs to be washed/wiped down.
ruger is offline
post #8 of 11 (permalink) Old 06-02-2014, 10:37 PM
Chuck A.'s Avatar
Put the bike on the center stand then get down and look with a slash light. Easy to tell if oil is in there or not that way.
Chuck A. is offline
post #9 of 11 (permalink) Old 06-03-2014, 06:03 AM
If your looking for a manual, they can be downloaded from my signature.
post #10 of 11 (permalink) Old 06-03-2014, 03:47 PM
luckily for me, I have a set of shoes with mirrors on them....I also use them for sighting the oil level on the bike....he he
