Equally poor compression? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 05-31-2014, 08:46 AM Thread Starter
Crowley
crowley1027's Avatar
Got a compression tester from autozone. Pulled a plug, and pulled the other three wires, and tested one cylinder at a time, and got just over 100psi in both cylinders.
Rear jug is burning oil.
I'm confused.
crowley1027 is offline
post #2 of 13 (permalink) Old 05-31-2014, 10:58 AM
place a tablespoon of oil into the spark plug hole and turn the enigne over several times then conduct your compression test as normal... if the compression goes back up, you have bad oil rings. If it stays the same you could have bad valve seals, or problems in the bottom end.
post #3 of 13 (permalink) Old 05-31-2014, 12:31 PM
i would do a leakdown test.
wmsonta is offline
post #4 of 13 (permalink) Old 05-31-2014, 09:05 PM Thread Starter
Crowley
I'm going to have to redo the test, because I got 140 psi out of one cylinder under separate circumstances.
I'll document the motorcycles variables before testing next time and post results.
post #5 of 13 (permalink) Old 05-31-2014, 09:15 PM
That is after he checks for bad rings... Since it's the fallowing step.
post #6 of 13 (permalink) Old 05-31-2014, 09:19 PM Thread Starter
Crowley
First numbers will come from the bike as follows:
Cold motor, center stand down, throttle wide open, both shallow plugs out, both deep plugs in (I still can't reach them!)
I'll test rear jug first, then front.
This winter will be rebuild winter - take the motor out, check cylinders and rings, get heads redone, new Balance dampers....
Anything else I'm missing?
post #7 of 13 (permalink) Old 06-01-2014, 10:37 AM
A leakdown will find bad rings, you will get air from the crankcase breather. Lots of it.
If you are going to do more compression testing, have the throttle open.
wmsonta is offline
post #8 of 13 (permalink) Old 06-01-2014, 11:39 AM Thread Starter
Crowley
Edited last post to add throttle
post #9 of 13 (permalink) Old 06-01-2014, 11:54 AM
18mm deep well sparky plug socket from craftsman to get the plugs even the deep ones..
I forgot the exact part number. but its posted here in several places.. do a search
post #10 of 13 (permalink) Old 06-01-2014, 11:57 AM
Sears will have 18mm "Thin Wall" Deep Socket hanging on the wall.
