exhaust popping while idling ?????????? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 05-30-2014, 03:12 PM Thread Starter
When I start the bike, the left pipe sounds normal while the right is popping, the air/fuel are adjusted right, I just can't figure it out ???????
rkama354 is offline
post #2 of 11 (permalink) Old 05-30-2014, 03:40 PM
Deviate's Avatar
Does it even out once it warms up some?
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #3 of 11 (permalink) Old 05-30-2014, 04:15 PM Thread Starter
no, it does it constantly, I tried to readjust the air/fuel but that didn't work so I sat them back.
rkama354 is offline
post #4 of 11 (permalink) Old 05-30-2014, 04:39 PM
Probably a vacuum leak in the popping cylinder. Does it run better with more throttle?
wmsonta is offline
post #5 of 11 (permalink) Old 05-30-2014, 05:23 PM Thread Starter
yes when I rev. the bike it does sound better, and when I take it out for a test ride, she does good.
rkama354 is offline
post #6 of 11 (permalink) Old 05-30-2014, 05:39 PM
If you still have the goat belly, it could be either cylinder. Probably a 'lean' pop. Check the vacuum ports and the mounting boots first.
wmsonta is offline
post #7 of 11 (permalink) Old 06-01-2014, 10:18 AM Thread Starter
Thanx every one for the help, we've cut down the popping quite a bit, but I have this question ? my vn has a bolt in the carb. hose that allows it to breath from the p/o and my vulcan runs great, is this a good thing or bad ?
rkama354 is offline
post #8 of 11 (permalink) Old 06-01-2014, 11:40 AM
Which hose.... A pic of the hose would be very helpful here.....
Seems like the Dead Air hose...follow instructions offered .
post #9 of 11 (permalink) Old 06-01-2014, 12:23 PM
Crowley
crowley1027's Avatar
Vent tube I believe. Sounds like he's saying *in the hose that allows the carb to breathe
In which case, I recommend attaching that hose to the nipple on the underside of the gas tank, where the fuel level sensor is.
crowley1027 is offline
post #10 of 11 (permalink) Old 06-01-2014, 12:43 PM Thread Starter
The hose that's on top of the carbs and goes to the back of the right air box
rkama354 is offline
