how do i add coolant to a 98 750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-25-2014, 06:06 PM Thread Starter
i know dumb question that i should refer to the manual but i dont have one at the moment
how do i add coolant to the system and what type would be best
1998 Vulcan 750
Krobar is offline
post #2 of 5 (permalink) Old 05-25-2014, 06:37 PM
Front ride side of the bike underneath the reflector panel.
post #3 of 5 (permalink) Old 05-25-2014, 06:42 PM
JM2001's Avatar
Use 50/50 mix antifreeze that says on the container" Formulated for aluminum engines " or states it is for aluminum engines ( SuperTech- Walmart). Take off the right cover just in front of the gas tank, 2 screws. Undo cap, open bleeder screw nut ( on top behind the filler neck. Pour slowly until antifreeze comes out the bleeder screw and the radiator is full. Fill the reservoir tank about 3/4 full.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 5 (permalink) Old 05-25-2014, 07:45 PM
2000 VN 750 Senior Member
I would suggest that you do a complete flushing of the system before you put clean antifreeze into a dirty system. Use the search feature and you should find all the information you need to do it even if you have no experience.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #5 of 5 (permalink) Old 05-25-2014, 07:59 PM
Originally Posted by Vulcan2000 View Post
I would suggest that you do a complete flushing of the system before you put in clean antifreeze into a dirty system. Use the search feature and you should find all the information you need to do it even if you have no experience.
.....As in, clean internals ( complete Cleaning/Flushing ) prior to just replacing Anti-freeze !
Tags
coolant
