Starting problems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 33 (permalink) Old 05-23-2014, 04:59 PM Thread Starter
1987 Vulan VN750-A
ro35647's Avatar
Starting problems
My Vulcan is in the shop, and the techs seem to be completely dumbfounded as to why it isn't starting. Great spark, carbs are working perfectly, and it cranks like nobodies business. What else could it be?
ro35647 is offline
post #2 of 33 (permalink) Old 05-23-2014, 05:02 PM
Did this just start happening, or after a service? Does it stumble @ all or just crank?
Pickup coils backwards?
post #3 of 33 (permalink) Old 05-23-2014, 05:14 PM Thread Starter
1987 Vulan VN750-A
ro35647's Avatar
Ah yes, a little background. I purchased a 2001 VN750 back in August for cheap, then it turned out the guy didn't have a title. In preparing the motorcycle, I had the carbs cleaned and got everything running perfectly. The guy never came through with the title.
Saved up a bit, and bought a 1986 VN750 (the one they are working on now). It had been sitting since 2008. Traded my other carbs off of my 2001, replaced the gas tank (had a little rust in it). It has shockingly good ignition, and carbs are running good, and kicks over like a mule, but won't catch and run.
Oh, and it will after like 10 turns backfire, then go back to turning over. They checked the valves on both to make sure ever thing was good, and everything is within tolerance.
ro35647 is offline
post #4 of 33 (permalink) Old 05-23-2014, 05:22 PM
Ah, one thing with older wiring (the 86) is power can be lost in the wiring harness, causing weak spark. It'll be 'decent' spark, but not good enough.
My bike would barely get started.. I swapped to iridium plugs, and an AGM battery (much better on the older wiring as well) and she ran amazingly well.
post #5 of 33 (permalink) Old 05-23-2014, 05:24 PM
Double check this.....wires get swapped ?
post #6 of 33 (permalink) Old 05-23-2014, 05:32 PM
On my '86, I avoided potential problems in this area....performed the Coil Relay Mod.
(Battery +12 v thru a standard relay directly to the coils...relay activated via original rear cylinder 12V supply coil wire.)
post #7 of 33 (permalink) Old 05-23-2014, 05:43 PM Thread Starter
1987 Vulan VN750-A
ro35647's Avatar
Already installed a AGM battery.
ro35647 is offline
post #8 of 33 (permalink) Old 05-23-2014, 05:44 PM Thread Starter
1987 Vulan VN750-A
ro35647's Avatar
Yea, I read about that too, but they insist I have GREAT spark.
ro35647 is offline
post #9 of 33 (permalink) Old 05-23-2014, 05:47 PM Thread Starter
1987 Vulan VN750-A
ro35647's Avatar
How would that even be possible? One is under the seat and one under the cover plate on the left side of the neck?
ro35647 is offline
post #10 of 33 (permalink) Old 05-23-2014, 06:18 PM
Not the Spark Plug cylinder coils.....
Pick -Up Coils ! .... the proper name ? ? ?
The coils behind the Stator Cover.
Wires come out together from the upper portion of stator cover...
If coils are swapped (or the wired connections swapped), each cylinder will receive it's spark at the wrong time (timing way off - will not run).
hth
