compression test - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-14-2014, 10:02 PM Thread Starter
Cool compression test
I have an '85 750 with 17,500 miles. The compression test shows 125 psi in each cylinder. Is this good?
tinman is offline
post #2 of 5 (permalink) Old 05-14-2014, 10:58 PM
emtdon's Avatar
yes and the fact it is the same on all cylinders is really good
Sent from Motorcycle.com App
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #3 of 5 (permalink) Old 05-15-2014, 09:14 AM
It is if you had the throttle closed or a cold motor.
wmsonta is offline
post #4 of 5 (permalink) Old 05-15-2014, 05:28 PM
JM2001's Avatar
Kawasaki spec is 129-199 lbs at 300 rpms. You are a little low.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 5 (permalink) Old 05-15-2014, 07:43 PM
If its an '85 US version, its a 700, not a 750....which in my opinion is a better engine (Im biased).....should be stamped by the bottom of the left side case.....should say "699cc"....
And that compression for something that old is great....my beat-to-heck 85 was getting around 115 rear, 110 front.....and I felt that was awesome....
