Engine Noise - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-18-2014, 02:11 AM Thread Starter
Question Engine Noise
Gday all, I have 86' vn750 twin, Au version. Done 27000Kms. After starting then run it erratically makes a spinning noise, pull clutch in noise still there, run in neutral while coasting noise still there but it goes away after a short ride...it also backfires and the front cylinder runs cooler than rear as I feel it with both hands at exhaust, anyone have an idea what it might be please?
regards
Mike.
michael2u is offline
post #2 of 4 (permalink) Old 04-18-2014, 08:38 AM
welcome...
as far as the spinning noise goes, it sounds a little like coffee grinder syndrome.. not all bikes affected by it. search the forums for threads on it, there is a solution (drilling clutch basket, or sometimes just different oil)
post #3 of 4 (permalink) Old 04-18-2014, 08:49 AM
Deviate's Avatar
Does it only make the spinning noise while you are moving or does it make it just sitting in neutral and idling on the side stand too?
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #4 of 4 (permalink) Old 04-20-2014, 08:17 PM Thread Starter
Gday mate, It makes the noise not long after warming up then running, I tried coasting with in gear and then clutch in but still makes noise yet it stops after about 5-10 minutes of riding.
