TOC MCCT question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-17-2014, 01:24 PM Thread Starter
iowa.rider's Avatar
TOC MCCT question
This past weekend, I put a set of TOC MCCTs on my bike. I adjusted them just enough to take out the chain slap, then stopped and tightened the locking nut. There is still a bit of a knock at idle. Is this just my imagination, or does everything sound normal? I'm fairly new (<1 year) to bike mechanics.
Here's a link to a video of it on YouTube: http://youtu.be/r3V6c5po1N0
Thanks in advance!
2001 VN750
AGM Battery
Battery Tender
TOC MCCTs added 4-13-14
VN900 seat
iowa.rider is offline
post #2 of 12 (permalink) Old 04-17-2014, 01:29 PM
Deviate's Avatar
That sounds about like mine does. Like a large sewing machine.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #3 of 12 (permalink) Old 04-18-2014, 02:16 PM
Yeah, sounds good. Makes me think I should tighten mine up a little because it's ticks a bit more than yours.
Topeka, Kansas, USA
89 VN-750A
riche is offline
post #4 of 12 (permalink) Old 04-18-2014, 03:27 PM
Sounds about right to me.
post #5 of 12 (permalink) Old 04-18-2014, 04:17 PM
First off, I love a nice clean motor! Second, that sounds about right. You could probably tighten them a tad more but it's in acceptable range to my ears. If she isn't giving you problems don't mess with it.
post #6 of 12 (permalink) Old 04-18-2014, 05:08 PM
Okiebezer's Avatar
Sounds good to me too!
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #7 of 12 (permalink) Old 04-19-2014, 02:12 AM Thread Starter
iowa.rider's Avatar
Thanks everybody! Went out this afternoon for a 20 mile cruise and she ran great. So much quieter than before at idle!
After some passenger education, my sister (who had never ridden before) went out with me two-up. It was definitely interesting to feel how drastically different the handling is with an extra 110 lbs. on the back...don't tell her I told you that tho lol. She had a good time, but admitted that she didn't like the feeling of the bike leaning while going around curves.
My only problem seems to be that my center stand scrapes the ground too soon when cornering tightly. I love having it there to hold the bike up when I'm wrenching around, and I usually put it down just to park it in the garage. The sidestand is just too short IMO. Any suggestions?
2001 VN750
AGM Battery
Battery Tender
VN900 seat
post #8 of 12 (permalink) Old 04-19-2014, 02:39 AM
My only problem seems to be that my center stand scrapes the ground too soon when cornering tightly. I love having it there to hold the bike up when I'm wrenching around, and I usually put it down just to park it in the garage. The side stand is just too short IMO. Any suggestions?
not that my post is on thread subject......
you already know....to be expected....definitely different (higher center of Gravity).
....new rider ...... LOL
enjoy
post #9 of 12 (permalink) Old 04-19-2014, 06:38 AM
Deviate's Avatar
Is your bike lowered at all? My center stand scraped after I put the shorter progressive shocks on the rear, especially riding two up. So I just removed it. I sill have it in the garage for when I change the oil or work on the bike. I just put it in place, slide the pivot rod through it and stick in the cotter pin. I don't use the spring. Then take it off again when I get done.
Deviate is offline
post #10 of 12 (permalink) Old 04-19-2014, 05:56 PM Thread Starter
iowa.rider's Avatar
It appears to have the stock rear shocks on it. I did turn them up to the 4 setting when she got on though. Usually ride at setting 2.
I'll probably end up popping it off and shelving it when going 2-up from now on. The scraping doesn't really bother me too much but it kinda freaks out the passenger. Thanks!
2001 VN750
AGM Battery
Battery Tender
VN900 seat
