foul plugs? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 04-09-2014, 06:20 PM Thread Starter
foul plugs?
I have a 1997 vn750, just took carb out and cleaned it. She idles fine now, except now my problem is the right exhaust sounds muffled. Could this be bad spark plugs?
Vulcanic is offline
post #2 of 3 (permalink) Old 04-09-2014, 06:36 PM
Big Nick's Avatar
Swap your plugs from the front pot to the back, and check if it changes anything, these engines are fairly high compression and plugs that spark well on the outside, can misfire under load.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #3 of 3 (permalink) Old 04-09-2014, 06:38 PM Thread Starter
Ok, going to change out the plugs tomorrow and will post an update. Thanks for the quick reply big nick
Vulcanic is offline
