Urgent question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 04-08-2014, 12:38 PM Thread Starter
kemen3's Avatar
Urgent question
I am changing the coolant in my bike and I broke the side drain plug on the engine. It is not leaking now and I have all the coolant drained. Will that hold up with it being broke? Or do I need to get it out?
If I do have to get it out. How do I do it without pulling the engine?Click image for larger version
Name:	ImageUploadedByMO Free1396975114.559572.jpg
kemen3 is offline
post #2 of 10 (permalink) Old 04-08-2014, 01:09 PM
If it's not leaking let it go.
Otherwise if you want it out you'll have to get an easy out set and be pretty careful not to mess up the threads. I didn't need to use the drain plug when I changed my coolant.
post #3 of 10 (permalink) Old 04-08-2014, 01:14 PM
If I was forced to remove that, I would not attempt to drill it without a pilot.
wmsonta is offline
post #4 of 10 (permalink) Old 04-08-2014, 01:22 PM Thread Starter
kemen3's Avatar
I'm thinking about just leaving it in there and keep checking for leaks. If I do that next time I change the coolant do I have to worry about it then or can I just use the other drains?
kemen3 is offline
post #5 of 10 (permalink) Old 04-08-2014, 02:23 PM
Deviate's Avatar
I would say that using the bottom drain and the radiator drain is going to get rid of most any coolant you need to. And if that one doesn't leak I would leave it alone.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #6 of 10 (permalink) Old 04-08-2014, 04:09 PM
Big Nick's Avatar
I'd fill it with liquid alloy,and forget it. More trouble than it's worth.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #7 of 10 (permalink) Old 04-08-2014, 04:16 PM Thread Starter
kemen3's Avatar
It's leaking. As soon as I fired it up it started coming out. onto Plan B. Big Nick what is that liquid alloyed you're talking about?
kemen3 is offline
post #8 of 10 (permalink) Old 04-08-2014, 05:27 PM
Roach's Avatar
Since you have a few threads to work with drilling it out might be an easy option.
I have a tool called QuikCenter that would make this a pretty easy procedure.
But you could also make you own. You just need a bolt the same threads as the broken one, and use a drill press to drill through it as centered as you can.
You can now thread this into the few threads you have. If it looks to be square, use it as a guide for a hand drill to pilot drill the broken bolt.
You then have the option to use a screw extractor.
Or you could plug it with something like JB weld and it'd hold forever. I'd make sure it's dry first and clean it out with brake cleaner.
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #9 of 10 (permalink) Old 04-08-2014, 08:05 PM Thread Starter
kemen3's Avatar
I got it out. I ended up using an easy out. Thanks everybody for your help.
kemen3 is offline
post #10 of 10 (permalink) Old 04-08-2014, 09:09 PM
Deviate's Avatar
One of the best tools ever made. Has helped me fix many a screw up.
Deviate is offline
