ACCT conversion to MCCT - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 04-07-2014, 04:54 PM Thread Starter
Limeybiker's Avatar
Unhappy ACCT conversion to MCCT
I have converted my original ACCTs to MCCTs. The procedure went fine until I had to re-install the coolant expansion tank. The problem is that the rear cylinder MCCT adjusting bolt gets in the way of the tank, and I can't fit the tank securing bolt. Has anybody else come up against this problem? I have secured the tank with a tie-wrap, but I'm not happy with that. Any ideas would be very welcome.
Just because you're paranoid, it doesn't mean that they are NOT all out to get you.
Limeybiker is offline
post #2 of 7 (permalink) Old 04-07-2014, 05:56 PM
Shorten that bolt a bit. I've done this a few times and I've always been able to get that tank back on. Just shave a few threads off at a time and you'll be fine.
post #3 of 7 (permalink) Old 04-07-2014, 06:07 PM
Okiebezer's Avatar
I recall another user voicing similiar issue. You could either install washer to help tank clear the bolt or heat tank slightly to create a dimple where the bolt rubs.
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #4 of 7 (permalink) Old 04-07-2014, 09:20 PM
....just a note.....
TOC mcct's ($100.00/set) ....this is not an issue.
post #5 of 7 (permalink) Old 04-07-2014, 09:30 PM
Just a note...we don't all have a spare $100 laying around...but we can probably come up with the ~$4.50 for this conversion.
post #6 of 7 (permalink) Old 04-07-2014, 11:34 PM
If I could do it again ( originally) ....I agree. ! !but zero regrets with past money spent.
Too easy !
post #7 of 7 (permalink) Old 04-08-2014, 12:34 PM Thread Starter
Limeybiker's Avatar
Thanks
Thanks for the advice.
I just went for a 20 mile test ride this afternoon. The engine is not ticking or rattling, and it drives fine, but now I have a minor oil leak from the rear MCCT. It must caused by gravity, because the front MCCT is bone dry. How annoying !
I think maybe the TOC solution is the way to go.
